1 - 2 of 2 Posts
Ok, so I was wondering if anyone here had a holeshot high mount on a 2005 sv? My question is does the high mount fit with the stock fender? From the holshot page I see the following description
Dale also was able to tuck the muffler up nicely so it will clear the stock rear blinkers and rear fender on the 2003 models if desired. The 2004 models require removing the rear black plastic fender and stock rear blinkers.
I thought 2003+ models were all the same. What is different about 04/05?
Do I pretty much need to get some sort of fender eliminator to be able to use a holeshot highmout on my 05. Thanks.
The subframe on the 04+ is lower by some number of millimeters. That would cause clearance isssues. I assume 04 and 05 are the same.
I have an 03 so I should have just let someone else answer.
1 - 2 of 2 Posts
