1 - 7 of 7 Posts
So I locked my gloves in my tail and my helmet locked on the side and now the lock will not open. I think maybe a glove is stuck in it? The key will not turn at all. I tried taking the main seat off but I cannot get my hands in enough to feel around in the tail. Any one have any ideas?
Thanks!
Did you push down firmly on the seat while turning the key?
I locked the seat on without connecting the cable to the lock. If you have the main seat off, unscrew the screws and remove the rivets to pull away the plastic.
yeah
tried jiggling, I think I might have to take the tail apart? or try to get into that inside area or somthing? I dunno
If it's a second gen you should have no problem getting through from the front seat, just move those relays and fuses out of your way and your hand should fit pretty far up in there.
1 - 7 of 7 Posts
