I just mounted a new tire and was wondering if anybody knows:
Front axle torque ft lbs
Front pinch bolt ft lbs
Front brake caliper ft lbs
No owners manual and cant find it on google?
Thanks!
remember how hard it was to remove the bolts and put at least the same effort into tightening them
that's not the smartest thing to do.
service manual says:
front axle: 47lbs
front axle pinch bolt: 16.5lbs
front brake caliper mounting bolts: 28lbs
someone uploaded the entire service manual to a website earlier this week. i'd search for it on here. it's 03+.
Front axle torque is 47 lb/ft or 65nm. Pinch bolts are 16.5 lb/ft or 23nm. Caliper bolts are 28lb/ft or 39nm. The service manual is what you need for torque specs, not the owner's manual. The service manual can be found here or in the stickied post in the FAQ section.
Edit:Beaten
Edit:Beaten
Thanks all!
Just put on my new road attacks! They ride great! Thanks for the help!
