A
aaron.robbins
·Guest
im installing a advance timing key and the stock one will not come out. what can i do?
With the mods you have already you find that it makes better power on top if you put it in backward! No kidding...avc8130 said:Or you could do it in conjunction with an oil change like I plan to. ac
really why ??DucOwner said:With the mods you have already you find that it makes better power on top if you put it in backward! No kidding...avc8130 said:Or you could do it in conjunction with an oil change like I plan to. ac
it will retard the timing 4 deg. that would be good for a high compression big bore with camscoyote said:With the mods you have already you find that it makes better power on top if you put it in backward! No kidding...really why ??
Yea if you have a pipe, filter and a stock jetted motor, advanced would be the ticketcoyote said:which i have none of :BangHead: sooo i guess i will just do it normally and go from there ...
