Are there any bad surprises awaiting me as I prepare to replace the broken clutch cable "holder" arm. I am hoping to simply unbolt the 2 bolts that attach the lower clutch adjustment (leaving the locknut/screw alone), pull the deal out, and put the new one in its place. Of course, nothing is ever as easy as it seems.
Will I need grease? and if so, what kind? Will the same grease I use on my Jeep work?
I have the shop manual at home, so that should help minimally.
