1 - 3 of 3 Posts
On the verge of blowing my bike up.
How does one get to the speedometer connector to fully remove the front fairing?
I have already basically takin the whole ******* front fairing apart and I can't get to the connector.
Is it under the seat or some ****?
If I remember correctly, the fairing should be removable without touching the speedo. After removing the two bolts on the side of the top fairing and the mirrors it should lift off. As I recall, the speedo is attached to the subframe which is attached to the steering stem portion of the frame.
The connector should run from the speedo to a connection under the tank. I was able to lift the front of my tank and then undo the connector. It should be easily removed from the back of the speedo as well.
1 - 3 of 3 Posts
