1 - 3 of 3 Posts
· Registered
I was changing out the front blinkers on my wifes sv650n, and for some reason the hex bolts on the sides of the headlight don't tighten. they pretty much just keep spinning both directions. I'm worried that some threading may be screwed but not sure.
doesn't seem to make a big difference as the head light still feels secure.
any ideas?
· Registered
There is a nut on the inside of the head light that you need to put on the bolt!! Take the two screws (Phillips) off the headlight casing and pry the bezel off from the bottom. You should see two loose nuts. Make sure you attach the wiring loom to the bolt before you put the nuts back on.
Cheers,
Jeff
1 - 3 of 3 Posts
