I wish I had a good answer but my hands fall a sleep after just 30 to 45 minutes. I have to flex and stretch them to keep them usable. Is this common or does someone have a good answer?
Fred
Fred
You should be able to wiggle your fingers at constant speed with no problem. You might also try shifting your seat position more. I go from up on the tank to back against the cowl. I usually ride back at speed and slide forward when I am doing something like tailing a car that needs my attention.Thanks for your help - the crampbuster looks like a good option. When you flex your fingers is is easy to loose control of the throtle.
Fred
