yeah and then when you twist the throttle you can twist the whole pod...Don't drill holes in your bars, not only do you limit the controls placement, but many handlebar manufactures say do not! Just file down the tabs on your controls but leave it a little proud so when you tighten down the controls it grips well to the bar. Not much tightening is needed, grips well!
The reason I went the grind tab route was the convenience of switching out bars and the warnings from manufactures.My bike is hours away from me for now and i dont remember seeing any tabs. I gotta go check again. If they were grinded down im assuming ill be fine since ive never had problems with them moving before. Everywhere i look on this subject there seems to be mixed answers lol. Thanks for your input guys
Drilling the handlebars would spoil it I guess. Avoid doing so instead consult to the dealer.Replacing my handlebars, do i need to drill holes for the controls. When i took the controlls off my previous aftermarket bars they had the holes drilled but i don’t remember seeing tabs in the drilled hole. Thanks in advance
