61 - 80 of 240 Posts
So I have 5 magnets evenly spaced. I can always redrill...
I did wire the sensor correctly, I even tried swapping the VCC and output, and still nothing.
I tried flashing a magnet in front back and forth, both polarities, and still nothing.
I am not an electrical guy, is there a way I can check signal with a Multimeter? What would I be looking for? What setting?
Great info here guys. Even the questions helped me sort some stuff out in my head.
...and the pictures and parts links just put the cherry on top. (excellent modeling skills gjscott!)
Thanks to drinkbrew for suggesting this thread. (It's not what you know, it where you know to look for it.)
Once I get all the parts gathered and installed I'll come back and post pics!
Thanks again.
Sympul
So what kind of sensor would i need in order to not need magnets? I have the Buell front wheel and there is no good place to put magnets on it that I can see. I have the speedo healer and want to pick up the 6 bolts holding the rotor on.
So put 6 magnets in the 6 bolts that you have and use the speedo healer to correct the difference.
Well I got my hands on the same hall effect sensor metioned above and got everything working on my bike. I did not use any magnets, just aligned the sensor with the 6 bolts and used a speedo healer to correct the difference in the signal.
The sensor has no problems picking up the bolts without any magnets.
Can someone guide me to a supplier for the sensor bracket ? It seems that there was a forum member that used to supply them. Thanks! Dave
Nobody really makes them anymore mostly because it is a very easy thing yourself. It doesn't take much skill to bend a piece of metal (aluminum or steal) and drill a couple holes in it.
So, a question for those that have used the GSXR sensor:
Are magnets still needed? It's the SV's clock that needs 'em right?
Would be handy if someone could spare the time and make a tutorial thread for this part of the front end swap.
It has been covered many times in the fork swap guide, yes you will have to read a bit but it is all in there.
The GSXR sensor is the same as the hall effect sensor mod, you need magnets either way. Both sensors do the same thing, they read the magnets and tell the speedo how many times the wheel has turned.
Don't place the magnets close to the bots that hold the rotor. I made tha mistake intitially because I am have galffer 9 rivert rotors and I couldnt place them there. The steel bolts distorted the magnetic field and the speedo was way off. Now I have placed the magnets on the outer ring of the rotor and it works just fine despite the fact that the magnets are not evenly spaced
Is there any specific purpose of the cups from Lee Valley Hardware beyond just to hold the magnets?
I found another set of magnets that fit neatly on stepped portion of the rotor hole and I don't need to use the cups unless they serve anther purpose.
