so i was in the dilema of needing a steering damper to get through tech. The sv doesnt really need one since its a pretty stable bike, but its required in the rules so i needed one. i had bought a 2005 or 2006 gsxr stock damper off ebay for like $20 when i was going to buy the 05 sv, and i also picked up a bracket off of Doug Z for the conversion.
unfortunately, the bracket doesnt work on the 1st gen SV, so I was kinda SOL, and looking at at least $220 for a used SV damper (scotts rotary)
Well being The Full Metal Doctor, I came up with a brilliant idea this morning after working on some foundation details. The basis wasnt my idea but solving the problems with the original idea came to me.
Wayne, my fiberglass and leather guy who also happened to race the SV a few years ago was over helping me with suspension. I told him about the damper and he suggested if i could find a way to hang it from the fairing stay i would be golden. Since its such a short stroke it wouldnt work attached to the frame.
This morning I came up with this
I removed one of the fork pinch bolts and inserted the slotted plate that I had made under the bottom bolt.
Then I attached the damper below where the pinch bolt went. re-torqued the pinch bolt just to be safe (but really there are 2 more bolts holding the fork in place)
I lined up the damper and drilled through the aftermarket fairing stay. I dont know what the stock stay looks like so it might not be feasible on the stock unit.
I then inserted a 5/16" diameter all-thread rod through the damper mount, and the fairing stay. Marked it to give me some leway and cut it down.
Put a locknut and a washer on the bottom side of the damper, a nut and washer on the top of the damper. a nut and washer under the fairing stay, and a washer and 2 nuts ontop of the fairing stay.
I had to also trim the bodywork back a little bit to allow for the atr to sit where it was. i originally intended for the rod to go through the front side of the fairing stay closer (the otherside of the tach housing) but there is a support rod below the mast.
results
pros:
Cheap damper to pass tech with
cons:
cuts down lock to lock steering by 1/4" to 1/2" each direction. and thats with the damper adjusted almost all the way out. this sucks moving the bike around the garage/pit but on my short test run, cornering inputs were not effected. I will have to test it out at the track before I declare it a full blown success
results
pros:
cons:
