161 - 180 of 1,056 Posts
Discussion starter · #171 ·
Is this for gen 1 or gen 2 SV?
If gen2 forget about it.
If gen 1, it's confusing what you are describing - is it TLR or SRAD?
TLR forks are 55mm at the bottom triple; SRAD are 54mm.
Neither triples will work with 06+ forks (53mm at the bottom clamp)
and you would only want SRAD triples with a Gen 1.
My bike is a 1st Gen. The forks are on a 1st gen now. described as a tlr fork swap. I asked if they were Srad triples axle and wheel. He said yes. Im a little confuse myself as Ive read the charts a million times.
Discussion starter · #177 ·
Arey ou sure they are SRAD triples?
What part of the set-up is TLR then?
- once more, TLR forks do not fit in SRAD triples.
And 00-03 600 forks are RSU
01-02 1000 are conventional caliper as are 00-03 750.
The spacing is different on all those GSXR options so you would need spacers.
He just now said that the lower is TLR and the upper is SRAD. But he also has the SRAD lower sitting around. The forks brakes would be TLR. Wheel and axle would be SRAD? Yeah, I knew about the older 600 being conventional, I just forgot to state that. Thanks for the input, it is greatly appreciated before I cough up money for something that isnt going to work for me.
Discussion starter · #179 ·
I'm not trying to get in the way of the guy's sale:
however - it sounds like you don't really want the forks or the TLR triple - maybe just the SRAD top & bottom triple & the wheel.
Even then if/when you get USD GSXR forks, if radial you will need 2.5m rotor spacers on that SRAD wheel and caliper spacers (5 or 10mm depending on which forks) or 2.5mm caliper spacers if on conventional forks
The TLR calipers will not fit conventional 00+ GSXR forks - different pitch between the mounting holes.
