801 - 820 of 1,056 Posts
Off topic, but does anyone know how disassemble the fork cap of a 04-05 GSXR600? like acutally take out the preload adjuster. I plan on getting my forks anodized and need to get the cap off. Id like to anodize the preload adjuster too to go more with my bikes theme
First remove needle (rebound adjuster), simply keep turning it in until you can push it out.
Than turn preload adjuster in few turns to expose circlip around silver part, remove circlip.
Now hold gold hex (32mm socket) and unscrew silver bottom piece (part with 2 flats for 17mm wrench). Pull it out.
Pull Blue preload adjuster out (o-ring is only thing holding it in once you remove silver part). Piece of plastic with 3 metal pins will fall out by itself at this point.
There is procedure to do it.
Turn jam nut all the way down.
Back out rebound adjuster all the way out, than turn it in for 3.5 turns.
Screw cap on until you feel resistance. Bring jam nut up against cap, hand tight.
Back out rebound adjuster.
Tighten jam nut against cap using wrenches.
Has anyone ever ordered Sonic Springs? I have a set and they are not tapered like the stock springs. Anyone know if they are directional or not? One side has the weight engraved. I PM Rich at sonic springs but he hasnt gotten back to be and was wondering anyone has had experience with them.
