GSXR Fork Information / Permutations
1 reading
527K views 1.1K replies 197 participants last post by  Bremsen
#1 · (Edited by Moderator)
Here is a summary of the different models of USD Radial forks used on the various Suzuki models.
Hopefully, this will concentrate all the dimensional information on the most popular SV/GSXR fork conversion possible configurations.
Let's start with the matrices for the dimensions of the various fork models:
Acknowledgments to Sam over at TL zone for initiating the primary chart creation and to all those who provided the data for it.
This excellent illustration courtesy of jeff721 will help indicate to what the measurements in the chart refer:
Of course, there are the non-radial USDs used on the 01-03 750 and 01-02 1000 but the Radial versions seem to be the most popular, so that is the focus of this post.
So - looking at the primary area of interest for GSXR Radial Forks:
2003/04 1000
Gold/black inner tubes; gold calipers
300mm rotors.
850 springs
32mm offset; 54mm lower clamp
Right offset ignition top clamp, 28mm bore
2005/06 1000
Bronze/black inners; black calipers
310mm rotors
950 springs
30mm offset, 54mm lower clamp
Center ignition top clamp, 28mm bore
2004/05 600/750 (same)
gold/chrome legs, gold calipers
300mm rotors
850 springs
Right offset ignition top clamp, 25mm bore
2006+ 600
gold/ chrome leg, black calipers
310mm rotors
900 springs
30mm offset, 53mm lower clamp
Left offset ignition top clamp, 28mm bore
2006+ 750
black/ bronze leg
310mm rotors
1000 springs
Calipers:
03/04 1000 and 04/05 600/750 (fit 300mm rotors std)
* The 03 1000 calipers are 4 pads per caliper - look the same as the two-pad variant
No interchangeable re pads however
All other GSXR models
Yamaha Monoblock (R6)
Caliper/Rotor Matrix:
Calipers can be utilized from all the models above, by using spacers* per this matrix.
* Note that although for some sizes it says N/A, this means the combo would be too tall;
however, you could actually machine the caliper (or fork leg stanchion) as opposed to a spacer
Triple Clamps:
You can mix & match a bit here:
The ideal top clamp I believe would be the 04/05 600/750 clamp
This has ignition offset to the right (same as SV and more conducive to the Vee shape of the front of the speedo for naked)
It has a 30mm offset and a 25mm bore.
Direct fit on 04/05 l600/750 lower triple clamp/forks
To fit on 06+ 600/750 forks/lower triple, bore stem hole to 28mm
To fit on 05/06 1000 bottom triple, bore stem to 28mm
If you have no access to machining, then the 05-06 1000 top clamp will fit directly on the 06+ 600/750 steering stem. This clamp has ignition 'straight ahead. The steering lock WILL lock, albeit with the wheel straight ahead, as opposed to the conventional full left position.
06+ 600/750 top clamps obviously 'fit' their own forks/bottom triple, however, the ignition is offset to the left; it requires some machining of the ignition module to avoid interference with the frame on the left side and the steering lock will not function without drilling frame. This makes it a less ideal choice.
Bottom clamp:
03/04 1000 has 32mm offset, 54mm bottom fork dia, and 25mm stem
05/06 1000 has 30mm offset 54mm bottom fork dia and 28mm stem
04/05 600/750 has 30mm offset, 54mm bottom fork dia, and 25mm stem
06+ 600/750 has a 30mm offset, 53mm bottom fork dia, and 28mm stem
Note that 06+600/750 forks are 53mm at the bottom clamp diameter - the others above are 54mm; so consider that as you wish to mix/match bottom triples & forks.
Axles:
The wheels are comparable fitment for all 01+ GSXR;
However, the axles change with the fork generations;
For the first group of forks per the caliper table above (03-04 1000 or 04-05 600/750)
uses an axle & collar nut (same as SV1K actually)
Note that there is no additional wheel/axle spacer required.
For the second group of forks (05+ 1000 or 06+ 600/750)
the axle has a threaded bolt, rather than a collar nut, with a separate spacer that goes between the wheel & right fork leg.
Steering Bearings:
All GSXR forks in the range above have 30/55/17 top & bottom bearings.
All Gen 2 SV650 and SV1K are the same sizes also
Gen 1 SV650 is the same bottom bearing but requires a special top bearing from TWF Racing.
Wheels:
All GSXR wheels after SRAD will fit any GSXR forks described above
The rotors change sizes (and fitment) however
Mix n Match Capability for Wheels/Rotors:
01-04 1000 and 01-05 600/750 and SV1K all are the same wheel dimensionally;
Will take 300mm rotors from 03-04 1000, 04-05 600/750;
Will take 310mm rotors from SV1K;
Will take 320mm rotors from any 96-03 600/750 or 01-02 1000 or TL, or Hayabusa
05-08 1000 and 06-07 600/750 take 310mm rotors only, from these years of the wheel only.
09+ 1000 and 08+ 600/750 take 310mm rotors only - note that these rotors are NOT compatible with the group immediately above & vice versa.
#1,029 ·
Wow what a thread. Thank you for the information bible on front swaps. Im thinking this bike will keep me tinkering for some time. Ive only had my Gladius a couple weeks and im already wanting to swap out the front suspension and brakes with it. Ive also found the rear shock not so good as well but i understand they are just a cheap bike . I know it would have been a cost exercise but figured by now Suzuki would have had the USD sets on them after pumping out so many GSXR. Pardon my ignorance but i cant see any posts on the newer model conversions? Mine is a 16 model and im looking at K6 or K8 GSXR600 parts.
Mine has centre ignition but i dont care if the steering lock works or not. Its not going to be raced but im a dirt biker and really appreciate better suspension(some of our roads here in OZ arent the best). Also im wanting to put taller MX bars on it not use clip ons. Would this be an issue? Any help much appreciated.
#1,031 ·
Taller bars will require longer brake lines. I believe your bike has a 28mm stem so most gsxr front ends would work. Keep in mind you need a top clamp with the same offset as the lower you get.
Sent from my SM-G973U using Tapatalk
Thanks Buddy,
Im getting the whole front end inc wheels and brakes so that means i just use the whole GSXR setup?. I figured i would need new brake lines so thats ok.The adventure bars should assist in more comfort for me(i think)
#1,039 · (Edited)
#1,044 ·
I happen to have a complete RC51 front end laying around. I believe the RC51 forks are 750mm from axle to top of tube, and they are 54mm lower / 50mm upper diameters, which, from what I could read should make them be a good fit for a set of 04/05 GSXR 600/750 triples and the whole thing should be pretty much bolt on to my 07 SV, and would still maintain the steering lock and everything?
That's why I was hoping to see the matrix. I actually had book marked this page many years ago when I was doing a different conversion. Its a great wealth of info!
#1,048 ·
Looks like center to center fork distance on the RC51 is 214mm, which doesn't match the 04/05 center (207).. so yeah that idea is probably out. caliper positions in relation to the disks would be jacked up even if I made an axle. Probably easier to just find a whole GSXR600 front end. Was hoping not to have to spend $800!
#1,050 ·
If I put the 2007 GSXR 1000 front end to my 2017 SV650 gen 3 will I need to buy the top and bottom bearings from allballs.com?
Also, does anyone know if my steering lock will still work?
What other adjustments may I need to make for this 2007 GSXR 1000 front end on to my 2017 SV650?
How can I find out which bearings are already on the GSXR front that is in the picture below?
#1,052 ·
Hello,
i may have a question which i didn't find the answer in the 29 pages of this wonderfull topic.
i have a sv1000s k3 with hyperpro front and rear springs (on oem shock for the rear) for years.
The rear shock is toasted and is leaking. I bought a olhins SU302 for gsxr 1000 with a 95N linear spring (i'm at 115kg in gear) but the bike feel weird, too soft on the front.
I think it may be come from the progressive hyperpro spring.
I already have some parts for a gsxr swap but my problem is with the length.
I looking for a gsxr 1000k5 fork (.95 spring, linear??) so 720mm, but the bike geometry will be off.
So, with the ohlins shock (upper from oem) and the 1000k5 fork (a lot lower from oem) , do some lower kit for the rear will put back an accepatble geometry?
thank you
#1,056 ·
Are there any resources for later model forks? I have the 04/05 triples/forks on my 2000, but was curious if any later forks would work in those triples on the SV. The forks on my bike are showing some corrosion/pitting and have a broken fender tab. None of its a big problem, I'm just wondering what options might be out there.
