GSXR Fork Information / Permutations
4 reading
528K views 1.1K replies 197 participants last post by  Bremsen
#1 · (Edited by Moderator)
Here is a summary of the different models of USD Radial forks used on the various Suzuki models.
Hopefully, this will concentrate all the dimensional information on the most popular SV/GSXR fork conversion possible configurations.
Let's start with the matrices for the dimensions of the various fork models:
Acknowledgments to Sam over at TL zone for initiating the primary chart creation and to all those who provided the data for it.
This excellent illustration courtesy of jeff721 will help indicate to what the measurements in the chart refer:
Of course, there are the non-radial USDs used on the 01-03 750 and 01-02 1000 but the Radial versions seem to be the most popular, so that is the focus of this post.
So - looking at the primary area of interest for GSXR Radial Forks:
2003/04 1000
Gold/black inner tubes; gold calipers
300mm rotors.
850 springs
32mm offset; 54mm lower clamp
Right offset ignition top clamp, 28mm bore
2005/06 1000
Bronze/black inners; black calipers
310mm rotors
950 springs
30mm offset, 54mm lower clamp
Center ignition top clamp, 28mm bore
2004/05 600/750 (same)
gold/chrome legs, gold calipers
300mm rotors
850 springs
Right offset ignition top clamp, 25mm bore
2006+ 600
gold/ chrome leg, black calipers
310mm rotors
900 springs
30mm offset, 53mm lower clamp
Left offset ignition top clamp, 28mm bore
2006+ 750
black/ bronze leg
310mm rotors
1000 springs
Calipers:
03/04 1000 and 04/05 600/750 (fit 300mm rotors std)
* The 03 1000 calipers are 4 pads per caliper - look the same as the two-pad variant
No interchangeable re pads however
All other GSXR models
Yamaha Monoblock (R6)
Caliper/Rotor Matrix:
Calipers can be utilized from all the models above, by using spacers* per this matrix.
* Note that although for some sizes it says N/A, this means the combo would be too tall;
however, you could actually machine the caliper (or fork leg stanchion) as opposed to a spacer
Triple Clamps:
You can mix & match a bit here:
The ideal top clamp I believe would be the 04/05 600/750 clamp
This has ignition offset to the right (same as SV and more conducive to the Vee shape of the front of the speedo for naked)
It has a 30mm offset and a 25mm bore.
Direct fit on 04/05 l600/750 lower triple clamp/forks
To fit on 06+ 600/750 forks/lower triple, bore stem hole to 28mm
To fit on 05/06 1000 bottom triple, bore stem to 28mm
If you have no access to machining, then the 05-06 1000 top clamp will fit directly on the 06+ 600/750 steering stem. This clamp has ignition 'straight ahead. The steering lock WILL lock, albeit with the wheel straight ahead, as opposed to the conventional full left position.
06+ 600/750 top clamps obviously 'fit' their own forks/bottom triple, however, the ignition is offset to the left; it requires some machining of the ignition module to avoid interference with the frame on the left side and the steering lock will not function without drilling frame. This makes it a less ideal choice.
Bottom clamp:
03/04 1000 has 32mm offset, 54mm bottom fork dia, and 25mm stem
05/06 1000 has 30mm offset 54mm bottom fork dia and 28mm stem
04/05 600/750 has 30mm offset, 54mm bottom fork dia, and 25mm stem
06+ 600/750 has a 30mm offset, 53mm bottom fork dia, and 28mm stem
Note that 06+600/750 forks are 53mm at the bottom clamp diameter - the others above are 54mm; so consider that as you wish to mix/match bottom triples & forks.
Axles:
The wheels are comparable fitment for all 01+ GSXR;
However, the axles change with the fork generations;
For the first group of forks per the caliper table above (03-04 1000 or 04-05 600/750)
uses an axle & collar nut (same as SV1K actually)
Note that there is no additional wheel/axle spacer required.
For the second group of forks (05+ 1000 or 06+ 600/750)
the axle has a threaded bolt, rather than a collar nut, with a separate spacer that goes between the wheel & right fork leg.
Steering Bearings:
All GSXR forks in the range above have 30/55/17 top & bottom bearings.
All Gen 2 SV650 and SV1K are the same sizes also
Gen 1 SV650 is the same bottom bearing but requires a special top bearing from TWF Racing.
Wheels:
All GSXR wheels after SRAD will fit any GSXR forks described above
The rotors change sizes (and fitment) however
Mix n Match Capability for Wheels/Rotors:
01-04 1000 and 01-05 600/750 and SV1K all are the same wheel dimensionally;
Will take 300mm rotors from 03-04 1000, 04-05 600/750;
Will take 310mm rotors from SV1K;
Will take 320mm rotors from any 96-03 600/750 or 01-02 1000 or TL, or Hayabusa
05-08 1000 and 06-07 600/750 take 310mm rotors only, from these years of the wheel only.
09+ 1000 and 08+ 600/750 take 310mm rotors only - note that these rotors are NOT compatible with the group immediately above & vice versa.
#837 ·
I figured it out....its the dust seals of all things. I got a set of aftermarket ones from All Balls Racing. They are pretty darn tight and were keeping the forks from compressing. I slid them down to check and now the forks compress no problem. Anyone know if there is a way to loosen up the seals or am i going to need to pull them off and use OEM ones?
#841 ·
I had a similar experience with All Balls fork seals. I replaced leaking seals in my 09 GSXR 750 FE with ALL Balls oil and dust seals. Upon partial reassembly I noticed that the tubes did not slide nearly as easily with the new seals. I went ahead anyway with the reassembly and they just didn't feel quite right back on the road. I ended up replacing the seals with OEM and problem solved. I spoke with All Balls after my initial concerns regarding the stiction and they sent me a new set of seals to try. Not wanting to swap out bad for bad I used OEM seals instead. Great customer service, dodgy fork seals? Got a set if anybody wants to try their luck.
#842 ·
Yeah i ordered them off amazon and i should have known that it couldnt have been right because it said like GSX-R600 99-15 for the years it fit. I went to the All balls website and put the year and model in and it gave me a different set of seals. The correct part number from All Balls for 04-05 600 forks is 57-108-1. Oil seals is 55-120. The combo is 56-133-1. New dust seals are waaaayyy better. Slide just as good as OEM.
#843 ·
I have a quick question:
I have 06 750 forks and I'm doing a swap on the 06 SV-N.
Will my original clutch cables etc work or will I be better off using riser bars? I'm trying to use TL1000 bars right now, but it looks like everything is going to hit something if I route the clutch cable this way. I might just try to get everything to work, but I'm wondering if there's something I'm missing.
Also, is it just me or are the bars really friggin low with this setup haha. I feel like I'm a foot lower in front than I would have been with the stock naked bars and a good 4-5 inches lower than the SM bars I had.
From the chart, it looks like the 06 750 forks are the longest of the lot too.
#845 ·
Do you know the difference in dimensions of the bars? My Google fu is being useless.
What do you mean reroute? Just pull the cables back under the tank or disconnect and reroute the clutch cable entirely? I'm going to have the brake cables going outside the forks, i.e. Not behind the headlight area. Is that kosher? Just wanted to make sure the routing didn't have to go behind her headlight assembly for safety reasons.
#846 ·
I think cbr bars 1/2-3/4 inch taller. I bought chinese ebay 1s for mine. I like'm, but bar ends suck. Basically plugs in tube. Re-route to take up slack is all I meant. As long as it is not hitting radiator. Or impeeding turn radius, u'll be all good. I have opposite problem. My throttle cable too short. Is pain in ass. Still have to re-route mine.
#848 ·
I would just stuff the wires in the headlight housing.
Speaking of wires, here is my solution for my vapor gauge. Fabbed it up myself out of 1/8" aluminum plate I bought on eBay. Powdercoated it semi-gloss black with an HFT powdercoater. Wires will probably route through the hole instead of downward due to the ignition. Might also have to grind down the ignition to make it all fit.
#850 ·
Yeah that bracket looks great. so your using the ignition to mount it that pretty crafty. I used the holes that are to the left and right of the steering stem hole to mount my vapor. Not as pretty but gets the job done. My problem is since im running my bike naked and with the stock headlight bracket you can see all the wiring to the headlight and what not. I have a projector mounted in my headlight so i cant stuff the wires into the headlight housing.
#852 ·
Did my swap today. Will post up a full log but here is a teaser. Didn't have good lighting for a money shot from the side. Overall, it was super easy and really only took a couple of hours. Really helps to do plenty of research. All that's left is wiring up the vapor, brake bleed, and overall shakedown.
Some key findings:
1. The rubber cushion clamps for the headlight bracket actually acted as perfect steering stops. They bump the frame right at the radiator mount bolt on both sides.
2. GSXR1000 straight ahead ignition was definitely ideal for Gen1. Only took a small amount of grinding with a dremel of the ignition body that rubs the frame to retain OEM steering lock function (bars turn left).
3. CBR1000RR bars felt good, but the bars themselves are too short to fit all the grips and controls. The grips hang off the edge by about 1/4" on both sides. Not enough room for bar ends and mirrors.
4. I fabbed a damper bracket out of 1/8"'aluminum that was about 1" wide in an L-shape. Damper rubs lower triple. Will have to revisit. Probably have to make it wider to give damper more space. It also bent slightly and too easily so I'll probably go with a steel L bracket of sorts instead.
#853 ·
I have TL1000 clip ons right now and was thinking of switching to CBR1000 clip ons for additional rise. The issue you're encountering is something I've read about before and it's definitely holding me back.
If I don't like the clip ons, I might just swap back to a bar since I have a triple I can do that with. It might be a better setup for longer rides, especially when coupled with a slightly bigger windscreen which I still need to get.
#858 ·
I did my swap awhile ago and im still working on tuning the suspension. How much travel should i have? I was reading articles online and it said it should stop 10mm before it bottoms out. Mine is not even close i rode it around over bumps and everything and bounced it myself and its like 75mm from reaching the bottom. And thats with no preload. The springs I put in are .80 and should be good for my weight. When riding i feel like it runs a little wide when i exit the turn.
#861 ·
I have the fork tubes flush (caps stick up) but my rear shock is a LOT longer than stock.
If when riding you're seeing 3" of unused travel you probably have too much front preload/spring rate.
#862 ·
I have about 2.5" before it bottoms out. I believe the spring weight is right for my weight. Im kinda concerned about the valving. I know the guy before me was like 100 lbs heavier than me and he had it tuned to himself. I know it was sprung heavier so i replaced the springs with lighter ones. Also i know when it comes to fork oil 5wt varies by manufacturer. I used Maxima 5wt anyone know if it is actually on the heavier or lighter side?
