GSXR Fork Information / Permutations
4 reading
528K views 1.1K replies 197 participants last post by  Bremsen
#1 · (Edited by Moderator)
Here is a summary of the different models of USD Radial forks used on the various Suzuki models.
Hopefully, this will concentrate all the dimensional information on the most popular SV/GSXR fork conversion possible configurations.
Let's start with the matrices for the dimensions of the various fork models:
Acknowledgments to Sam over at TL zone for initiating the primary chart creation and to all those who provided the data for it.
This excellent illustration courtesy of jeff721 will help indicate to what the measurements in the chart refer:
Of course, there are the non-radial USDs used on the 01-03 750 and 01-02 1000 but the Radial versions seem to be the most popular, so that is the focus of this post.
So - looking at the primary area of interest for GSXR Radial Forks:
2003/04 1000
Gold/black inner tubes; gold calipers
300mm rotors.
850 springs
32mm offset; 54mm lower clamp
Right offset ignition top clamp, 28mm bore
2005/06 1000
Bronze/black inners; black calipers
310mm rotors
950 springs
30mm offset, 54mm lower clamp
Center ignition top clamp, 28mm bore
2004/05 600/750 (same)
gold/chrome legs, gold calipers
300mm rotors
850 springs
Right offset ignition top clamp, 25mm bore
2006+ 600
gold/ chrome leg, black calipers
310mm rotors
900 springs
30mm offset, 53mm lower clamp
Left offset ignition top clamp, 28mm bore
2006+ 750
black/ bronze leg
310mm rotors
1000 springs
Calipers:
03/04 1000 and 04/05 600/750 (fit 300mm rotors std)
* The 03 1000 calipers are 4 pads per caliper - look the same as the two-pad variant
No interchangeable re pads however
All other GSXR models
Yamaha Monoblock (R6)
Caliper/Rotor Matrix:
Calipers can be utilized from all the models above, by using spacers* per this matrix.
* Note that although for some sizes it says N/A, this means the combo would be too tall;
however, you could actually machine the caliper (or fork leg stanchion) as opposed to a spacer
Triple Clamps:
You can mix & match a bit here:
The ideal top clamp I believe would be the 04/05 600/750 clamp
This has ignition offset to the right (same as SV and more conducive to the Vee shape of the front of the speedo for naked)
It has a 30mm offset and a 25mm bore.
Direct fit on 04/05 l600/750 lower triple clamp/forks
To fit on 06+ 600/750 forks/lower triple, bore stem hole to 28mm
To fit on 05/06 1000 bottom triple, bore stem to 28mm
If you have no access to machining, then the 05-06 1000 top clamp will fit directly on the 06+ 600/750 steering stem. This clamp has ignition 'straight ahead. The steering lock WILL lock, albeit with the wheel straight ahead, as opposed to the conventional full left position.
06+ 600/750 top clamps obviously 'fit' their own forks/bottom triple, however, the ignition is offset to the left; it requires some machining of the ignition module to avoid interference with the frame on the left side and the steering lock will not function without drilling frame. This makes it a less ideal choice.
Bottom clamp:
03/04 1000 has 32mm offset, 54mm bottom fork dia, and 25mm stem
05/06 1000 has 30mm offset 54mm bottom fork dia and 28mm stem
04/05 600/750 has 30mm offset, 54mm bottom fork dia, and 25mm stem
06+ 600/750 has a 30mm offset, 53mm bottom fork dia, and 28mm stem
Note that 06+600/750 forks are 53mm at the bottom clamp diameter - the others above are 54mm; so consider that as you wish to mix/match bottom triples & forks.
Axles:
The wheels are comparable fitment for all 01+ GSXR;
However, the axles change with the fork generations;
For the first group of forks per the caliper table above (03-04 1000 or 04-05 600/750)
uses an axle & collar nut (same as SV1K actually)
Note that there is no additional wheel/axle spacer required.
For the second group of forks (05+ 1000 or 06+ 600/750)
the axle has a threaded bolt, rather than a collar nut, with a separate spacer that goes between the wheel & right fork leg.
Steering Bearings:
All GSXR forks in the range above have 30/55/17 top & bottom bearings.
All Gen 2 SV650 and SV1K are the same sizes also
Gen 1 SV650 is the same bottom bearing but requires a special top bearing from TWF Racing.
Wheels:
All GSXR wheels after SRAD will fit any GSXR forks described above
The rotors change sizes (and fitment) however
Mix n Match Capability for Wheels/Rotors:
01-04 1000 and 01-05 600/750 and SV1K all are the same wheel dimensionally;
Will take 300mm rotors from 03-04 1000, 04-05 600/750;
Will take 310mm rotors from SV1K;
Will take 320mm rotors from any 96-03 600/750 or 01-02 1000 or TL, or Hayabusa
05-08 1000 and 06-07 600/750 take 310mm rotors only, from these years of the wheel only.
09+ 1000 and 08+ 600/750 take 310mm rotors only - note that these rotors are NOT compatible with the group immediately above & vice versa.
#631 ·
Pretty sure the offset has to match upper and lower for them to line up. Not sure tho on mixing and matching how that works.
http://bikearama.com/theory/motorcycle-rake-trail-explained/
Motorcycle offset: The distance between a line drawn through the centre of the steering stem/ headstock axis and the centre line of the front fork tubes. Typically the offset inversely affects trail, if offset increases then the trail will decrease.
Motorcycle trail: The distance on the ground between a straight line drawn through the center of the front wheel spindle and a line drawn through the center of the headstock axis. The greater the trail distance, then the greated the straight line stability but the harder it is to make the bike corner.
To fix any issues with steering you can adjust the distance the forks are higher in the triples. Raising the triples on the tube adds stability but reduces cornering. Lowering the triple on the tubes speeds cornering but you loose stability at high speeds. Generally you want to lower the front to get it to corner. If it feels twitchy you can raise it up a little to add stability.
#637 ·
Thanks for the explanation. I think I'm just going to find an 08 triple though. Just realized that I won't have any lock because the ignition is to the left... Now I'm just wondering how much of the ignition needs to be trimmed. I can just use a dremel or file for that though, right? Don't see the need to have it super accurate.
Do your research kids...
#640 ·
What do i need to do to fit an 11-13 front wheel to 06-07 600 forks and axle?
Is it a simple wheel bearing swap? Or an axle swap, and if so, will 11-13 axle fit the 06-07 forks?
thanks in advance, Greg.
To my understanding the bearings are the same diameter. You will need the same yr axle but I do believe 06 & up the axle is the same. Some one correct me if I am wrong!
