201 - 220 of 1,056 Posts
I'll expose myself as a GSXR swap noob. I think I have done my research and decided what I want. But this post isn't about that. This post is about a potential mistake in the OP of this thread.
The chart lists 600/750 K6/K7 as being the same. Further down in pictures, the 600 K6+ is shown as gold and having 900 springs. The next picture shown is a 750 K6+ and black forks are shown and 1000 springs are listed.
So am I reading this wrong or is the post wrong?
Discussion starter · #205 ·
ok so im tryin to buy a 06 gsxr front end for my 05 sv 650. will i need a 04-05 gsx1000 top triple for the steering lock and for the center ignition? [/qupte]
If you want those features (steering and center ignition) then you would want 05/06 1000 top clamp (04 & 05 are different models on the 100)
If you want 'right' side ignition, you want 04/05 600/750 clamp but it needs to be modified with the stem hole over-bored to 28mm
will i need a new master cylinder for the brakes?
Ideally, yes - the GSXR ones are good cost-effective choice to match the new calipers.
ok so im tryin to buy a 06 gsxr front end for my 05 sv 650. will i need a 04-05 gsx1000 top triple for the steering lock and for the center ignition? and will i need a new master cylinder for the brakes?
I have one ,it would include m/c, lever, and res $60 shipped, I also have a set of calipers for 06+ front end w brake pads $65, clip ons $50
thanks for the quick replies. im reading up on a lot of this stuff and its a lot of info to digest. if i wanted to swap the 06 gsxr front end onto my sv what problems would i run into besides the ignition and steering lock? from what i read other than those it seems like a pretty straight forward swap.
I recently did a fork swap on an SV1000, which uses the same front wheel as the 01-05 GSXR you mention. I was told to use the 06-07 axle. You'll also need to do something to get the brake rotor diameter right...
06-07 GSXR forks? As for the brakes, I have a set of spacers in mind for that, but I'm not so sure about caliper bolt lengths.
Great info D'Ecosse. After 4 yrs of racing with the stock front end on my 05 Sv650 I've swapped the front from my 05 GSX-R600 yesterday and going to try it this weekend. My question is about steering dampers, what do you recommend. I have Attack triples upper and lower. The ohlins damper from the gixxer is mounted fork leg to OEM threaded hole at steering head so not transferable. Any ideas?? thanks in advance!
Discussion starter · #219 ·
Any of the steering stem mount rotary type will work well - many will sell you hybrid kit with a GSXR mount for top clamp but SV frame (tank) mount
Talk to Zoran about that - think he can do a PitBull kit for you
