1 - 10 of 10 Posts
Hey Guys
Please give me your opinions on this
Our current rim combination / tyre race setup is :
Pirelli Super Corsa's SC 2 back and front
Standard SV - 3.5 inch front rim using a 120/70/17
Suzuki GSX R 600 - 5.5 inch rear rim using a 180/55/17
Have any of you racing guys used this combination yet .. please give me your opinions .. I am wondering how the standard SV back rim - 4.5 inches using a 160/60/17 performs in comparison due to the diffent profile
Lastly what would your opinion be on fitting a 180/60/17 ( higher profile) onto the GSX R rear rim .. and going up one tooth on the rear sprocket to compensate for the larger tyre ?
I refuse to open this can of worms. Do a quick search buddy. You will find this topic has been heavily debated.
180 last much much longer, thats best gain.
I cant tell much of a difference between the 2 when riding.
Up here we have always run SC1 Front with SC2 rear. Our temps never get as high as yours down south so maybe thats why. The fronts last forever so I can't imagine how long a SC2 would last.
The difference between a 160 to a 180/55 is 2 teeth. The difference between 180/55 to 180/60 is almost another 2 teeth. I couldn't beleive it untill I measured it. On a first gen a 180/60 leaves about 1mm clearance to the swingarm depending how far back your axle is. Can'tfit warmers. Not sure about a 2nd gen?
I had thought about running 180/60's untillI compaired them to the 180/55. The 60is a very big tire. Bigger in every dimemsion than the older 190. Alot heavier as well,so as long as 180/55's are available I will be running them.
FYI I was talking to Kevin Graham acouple of weeks back at the nationals to confirm compounds and 180/55 DOT's use the same compounds as current 180/60's but the 180/55 slicks are still the older compounds. So if you notice differences this may be why.
He indicated 180/55's are sold as soon as he gets them in. I know I had to wait a month to get some this year, so order early.
I don't notice a big difference in feel between 160's and 180/55's. It's just a bit more planted and doesn't squirm as much as 160's on corner exit.
Well this thread is about the rears, so this is just a side note, but I made the switch to the SC2 front a year or two ago. Grip is just as good as the SC1 but the tire is a little stiffer, I feel that it gives a little more feedback, it retains its shape a little better & lasts a little longer. Most of the other SV guys are now running the SC2 front at Loudon as well.
As always, your mileage may vary. Tracks, bikes, riders, riding styles all differ and may require different compounds.
1 - 10 of 10 Posts
