1 - 20 of 44 Posts
can anyone recommed a decent gps unit that is $200 or less? do I need bluetooth?
thanks guys
I'm assuming motorcycle specific correct? Most of those are in the $500+ range. What kinds of features are you looking for?
Less than 200 ... go to ebay or look at the pawnshops.
Most car units will work but are not waterproof..
Make certain you don't get one with a hard disk, they WILL fail on motorcycle service..
Discussion Starter #5
i thought there were ones like the quest etc that were waterproof..are these no good..sorry I am little clueless with GPS units and there is so much info out there its hard to figure out which is a good unit for me..i just need a unit that is easy to use, waterproof and i can mount to my bike
You get what you pay for ... 200 is not enough IMHO.
You don't need bluetooth, it is not stable anyways cause cars using bluetooth cellphone/headsets disrupt coms. :angry4: Gave up on using that.
Vibration is the killer on motorcycle on GPS units. Seen people use freezer ziplocks for rain protection.
Ebay Garmin Quest
This is the GPS I have on my bike, its water proof, shock/dust resistant it does have turn by turn directions but idk if you can do the blue tooth thing, so no you don't need blue tooth. Its 86$ for a practically new $400 GPS, I have the same one bought from the same seller and have no problems.
I've had the same one for 3 years, mounted with a cradle and clamp from RAM Mounts. It's probably done 5000 mi on the SV as well as a bunch of time on my Kawi where I use it both as a speedometer and to keep from getting too lost. It has survived a bunch of crashes on the kawi including a couple of shots into trees, runs like when it was new even though the case and mount are a little scuffed. My worst rainy day was a 12 hr ride from the VA border to GA that was mostly in rain and some thunderstorms that even dropped a little hail, the Quest was fine.
I recently picked up a Garmin Nuvi 500 because Amazon had a great deal on them (still outside of your range but not by much). I'm going to use the new one on the SV and use the Quest for 100% offroad.
For the price it can't be beat. Get the RAM mount.
Discussion Starter #9
i didnt mean bluetooth was a requirement ..i was asking if its necessary.. i dont need all the bells and whistles...i just need something that gives good and easy to read/follow directions..is waterproof for my bike etc
also it would be nice if they are easy and cheap to update (but not necessary)
I currently use my I phone. It works great and I travel the whole state. Refurbished 8GB units are running 100 bones. I found a motorcycle mount (yet to buy) for $85.
Ebay Garmin Quest
I picked my Quest I up for around $90 reburbished on Amazon. The Quest II you will not have to load maps for detailed info though and the same size.
I have the Garmin Zumo 450, but if I had to do it over again, I'd go for the Lowrance XOG
I didn't get a ram mount. I used the car cradle it comes with and that black disk. Cut the black disk down to size and stick it to your triple. Then you can wire a 12v accessory into your battery with a switch and you never have to worry about it dying :)
And if you travel places where there aren't cell phone towers or where their signals are overcome by interference (some mountaintops)?
No mountains here and just my .02 / my experience with the gps function.
I've been using the Zumo450 for a few seasons now and love it (outside of a couple of times where it froze and required removing the battery to reboot it)
What is better about that Lowrance?
1 - 20 of 44 Posts
