1 - 10 of 10 Posts
Was going to install my lines, got galfer SS for front and rear on a group buy a while back. However, I noticed the front of the bike has 3 lines, not two if you include the first section. Looks like I only got a 2-line front kit in the group buy, and obviously I want to replace the 3rd line... soooooo where can I get one? Can I get just this line individually?
You most probably got a two-line front kit. Two lines directly from the master cylinder to their respective caliper. You'll notice they're longer than any of the 3 lines on the bike, correct?
reomve all the lines AND the fluid splitter bolted to the lower triple. Replace from the master cylinder directly to each calioer as stated.
awesome! thanks guys. I thought they were pretty long but for some reason that didn't even cross my mind. Easy enough then I guess.
right on.... a monkey could do the job with those instructions!
:wink: things just arnt as hard , as people make them out to be is all :)
1 - 10 of 10 Posts
