1 - 7 of 7 Posts
Did search already but few clear answers. Anyone try a 120/70/17 front along with 160/70/17 rear tire at the same time. I never liked the stiff 120/60/17 front sidewall and figured the taller 70 series sidewall would also correct the speedometer while softening the ride. Since the 160/70/17 rear would add a little extra rear ride height it would restore the lost front 60 series turn in speed and would give slightly better highway rpms along with a slightly softer ride. At least that's my theory. Any thoughts? I already know it would add slightly more unsprung weight and havent seen any reported clearance issues. These sizes are available in the Bridgestone Bt023 tires.
I just installed a 70-series BT-016 to replace my worn Conti Sport Attack 70 tire. Just make a minor adjustment (raise the fork tubes in the clamps 5-10mm) and it's all good.
The new Bridgestone and the front-end feel are excellent. Go with a 70.
I have always had a 60-series rear tire.
If you are replacing the stock Dunlop 220 the difference will be night-and-day.
I wouldn't even bother touching the geometry. Just put the tires on & be done with it.
If you don't like how it handles, then make some changes.
Steers too quick? Drop the forks down a couple mm in the clamps.
Steers too slow? Pull the forks up a couple mm in the clamps.
1 - 7 of 7 Posts
