1 - 2 of 2 Posts
Well I can finally go pick up my new bike this weekend and I was looking for pointers on securing it in the back of a 1/2 ton so it won't fall over. I am guessing use the kick stand and herc strap the front so there is some compression on the front forks and tie down the back so she won't wobble. Is there anything that I am missing like a couple of mattresses ???
No, you sound like it is ok.
Only thing that helps is a Canyon Dancer across the handle bars. Then the tie downs hook on the end of those.
Then just run a tie down from one tie down point of the truck through the passenger peg gaps to the tie down on the othre side.
You should be golden......
1 - 2 of 2 Posts
