Hey guys Just a little heads up , I've seen some threads on here where people dont like the stock exhaust.. M4 is Making a slip on for it, Looks pretty trick.I'll see about getting pictures for you if wanted.
Oh aye get it stuck on.
Madjohn.
I had an M4 slipon on a k4 gsxr 600 and it was nice. It would be great if you could find out if they intend to do a full system? Also, somebody on the forum had mentioned they were pretty sure that a full system from an 03 or later sv650 would probably fit. I would keenly be interested if someone can confirm that, too. To me, if the only thing that has to be done is fabricate a new canister mount onto the rearset, that's no problem.
Well as far as direct application Slip on are only being made.. But im pretty sure that its the same sv650 motor .. so the fullsystem may work.Good question.
The Full system Does not Fit the Gladius! JUST An FYI!!!
Ok Tex tx for checking...I'm anxious to jump on the first full system that gets to the US that looks/sounds decent.
