Need some help and replacement links if possible. Now the story:
I am getting my daughter's '09 SV650S ready to sell for her and it had some junk in the tank. I puled everything apart and cleaned the tank as well as the sticking TBs but it still wouldn't fire.
I pulled the pump and cleaned all the gunk per a prior thread I found, put it back together with clean fuel and same condition. I pulled the plugs and cleaned them but still no luck. I then put a little fuel direct into the TBs and was able to get it to fire but it never stayed running so I am wondering if the pump itself is plugged with gunk.
I cleaned everything else and had good flow out of the plastic HP assembly. I can hear the pump initiate at key on, have enough fuel but it still won't fire. All fuses are good, relay clicks, pump whirs, etc. so I am thinking there has to be a blockage somewhere that won't let the pump draw but how do I test this out of the tank?
What are my options? I could use a link for a shop manual too if you all have one to share.
Thank you in advance!!!!
