1 - 19 of 19 Posts
After getting mountains of crap from Josh about not having items for the 2nd gen SV, we finally have something to shut him up!!! Hot off the CNC machine..... 140mm dogbones for the Gen2! Raises ride height about 9mm over stock. We experimented with several lengths and DucOwner got the slide rule out and finally settled on 140mm. Available raw tumbled aluminum or annodized gold or black.
http://www.motospecialties.com/MSIn...ype=Products by Bike&Type1=Suzuki&Type2=SV650
Would that be too radical of an increase for spirited street riding and occasional track days?
no. its about perfect for track riding, you'll just notice easier turning on the street at street speeds.
It should also give a bit more ground clearance for the lower 05 pegs, right?
05s dont have lower pegs...
Novadesigns said:
So how would this work with a GSX-R front end, since that already drops the front a little bit?
gsxr forks dont drop it too much.. especially with 70 profile front tire.
with your gsxr1000 shock you could probably use these dogbones to get more ride height and faster turn in.
I could have sworn that, side by side, the 04-05 bikes have a different (lower) peg assembelly than the 03 bikes. Looks like the pegs are about an inch lower.
They have different parts fiche on RonAyers.....
it is a different design, but to my knowledge peg height is the same.
I wouldn't put that on a second gen SV, the spring rate is going to be really far off unless you're huge.
+1 busa shock has super stiff spring rate
I have been feeling like the bike's rear end is a little low. I think that I will probably still wait until after the front end is done. One thing at a time, easier to get used to and adjust.
From what i hear they changed the rearsets on the 04-05 svs because people said the 03 svs rearsets were to aggresive.
I have the gsxr front end and the dogbones and love it. However i had the gsxr front end extended to stock sv length.
1 - 19 of 19 Posts
