1 - 3 of 3 Posts
If you were out of gas, would it illuminate when you turned on the key, or would the motor have to be running for it to light up?
dp
It's solidly illuminated when the key is on but the motor is not running. Once the motor runs it then reads accurately.
Slosh the tank around side to side?
I think there is a little delay. Sometimes when going to work, it will start flashing, but then going home it takes a couple blocks before it starts flashing again. I've never run it really low to see if it is more "insistent" when the fuel gets lower.
1 - 3 of 3 Posts
