Remove the bolts at the front of the tank where it attaches to the steering head, prop it up to remove the fuel line, fuel level sensor/fuel pump power and vent hoses, set the tank back down. Remove the 12mm bolt in the hinge under the seat that goes from the right side to the left. Once that bolt is out, you can lift the tank straight up.how do you remove the tank? I've looked at the hinge and am not sure how to move it.
And when you reinstall, put the long bolt back through the pivot and get the nut on it but don't tighten it down. First, lower the tank and make sure everything lines up then install and hand tighten the front bolts, check alignment again, then tighten the pivot bolt. Last, prop it up again and install all the hoses, etc.Remove the bolts at the front of the tank where it attaches to the steering head, prop it up to remove the fuel line, fuel level sensor/fuel pump power and vent hoses, set the tank back down. Remove the 12mm bolt in the hinge under the seat that goes from the right side to the left. Once that bolt is out, you can lift the tank straight up.
