I know that the ones for 03 use a different plug than the newer ones. 3 prong vs 4 prong. I believe its for the low fuel light flashing thingy. Check your fuel pump plug, if its 4 prong you should be ok. Or if you're reusing the old fuel pump you should be good to go as well.
