1 - 12 of 12 Posts
I know we have just about kicked this octane thing to death. But, I'm curious what effect the 85 or 86 octane regular gas out West has on engines. I do know that the higher in elevation the thinner the air gets. So taking a sea level bike to 5,000 ft. or above will definitely richen the mixture.
What octane do y'all in those mountain states run in the SV engine? Will the 85 or 86 octane cause the SV engine to ping?
Cheers! 8)
I use 85 here in Colorado.... Never had a problem. I started using 91, and then switched down. Couldn't tell a difference at all...
I'm in Colorado as well & I use mid-range (87 here). No problems whatsoever.
A rich mixture is more resistant to pre-ignition than a lean mixture. Octane (per grade) is generally lower in higher elevations. IIRC, the higher elevation lowers the effective compression ratio as well. (Note that drag racers run more blower overdrive at higher elevations like Bandimere Speedway in Colorado to make up for it.)
Altitude - The higher the altitude above sea level, the lower the octane requirement.
What about your attitude?
Heh, I read it the same way...
8) Thanks to everybody that responded! ;)
+1 avation fuel is lower octane then regular pump gas, it is rated differantly, i knew someone that bragged about using avation fuel in his car, i laughed at him telling him that it is a lower octane, he was a tool
1 - 12 of 12 Posts
