1 - 3 of 3 Posts
I am having gas spray out of the fuel injector on the front of the throttle body. The oring/seal look fine, but the injector basically just slips out now. Is there a way to make this seal tighter with some sort of glue or something? I can't find the part number for the seals to replace them either.
http://i.imgur.com/g9eXM.jpg
http://www.ronayers.com/Fiche/TypeI...up/THROTTLE_BODY_FITTING_(MODEL_K3_K4_K5_K6)_
Most likely you just need a new seal. #2 above. But I'd bet they are the same diameter as most cars use on their injectors and any parts store should have them for much cheaper. Heck, any shop that does engine work will have them by the scores just laying around as they come in every gasket set and many times aren't used. Wouldn't hurt to check.....or just pony up the cash for 'Genuine Suzuki' O-rings.:)
1 - 3 of 3 Posts
