1 - 3 of 3 Posts
My wife's gas cap lock is corroded and needs to be replaced on her Ninja 650R. Is it possible to just replace the gas cap or do I have to replace the ignition and seat lock at the same time? I would want all 3 on the same key as they are now.
if its just the lock and not everything else i would suggest calling up your local locksmith and see if they can do a match for you a whole new lock assembly for just the tank would be around $200 and if you want everything to match it will cost a few hundred more. if you can find a locksmith with the correct size tumbler (i think thats what its called the thing the key actually goes in) and can match it to your keys it will be WAY cheaper.
1 - 3 of 3 Posts
