Any one know what re jetting for a full exhaust system will do to the fuel milage?
If I under stand it right, the re-jecting will richen the mix= more fuel use?
A little... But you'll get better mileage after a rejet than you will with a full system and no rejet, because inefficient running kills your economy. With my system, filter and rejet it took maybe 5 miles of my tank range with day to day riding, but a lot more at full pelt. Also, while you're burning more fuel at any given throttle opening, you're also making more power- so that ofsets it a little for less demanding riding, as you can get the same results with less revs and therefore, less bangs.
Nothwind...Can the same be said for re-mapping of the 2nd gen bikes? Anyone have some hard numbers to back it, or is it all theory?
It should do... Although the injected models seem to benefit less from bolt-on filters. With the carbed bike, if you stick a good filter and system on it but don't rejet it'll run like an absolute dog. A seriously lean or rich bike burns very inefficiently, so it basically wastes fuel. That also has other knock-on effects of course.
I'm making a bit of a presumption that Drift has an aftermarket or modified filter, or would fit one- spending $$$ for a full system makes very little sense if you skimp on the intake side.
Don't misunderstand though, putting a full system on a bike isn't really compatible with economy. If you want good mileage, put a 16 tooth front sprocket on and leave the rest pretty much standard. A good slip-on should help out. But like drift says, the entire point of a full system and filter is to get more air in and out, so you can get more fuel in and get more go per bang.
I lot about 20% fuel economy when I had my V&H full system & jetting done, I got about 5%-8% back when I went to a 16t countersprocket
Cool. I would defiantly re-jet with a system. I was just curious how much of a drop in MPG I would see. If it was excessive then I would just go with a slip on. I hate to kill the milage for the small gain of performance and a good look.
I will do a Penske first. Money better spent for true performance gains.
Thanks all!
