1 - 3 of 3 Posts
I'm having a problem with my 2000 naked. If my tank is more than 3/4 full, I get a leak around the cap (between the aluminum ring and the tank on the left side. It gets worse if I accelerate hard or corner.
I've looked at the rubber ring on the cap, and nothing seems out of place. Could this be a plugged drain line, and if so, where should I look?
The drain line can become plugged. The drain tube is also known to rust through and leak, or pull loose inside the tank and leak. Do a search. There are relatively simple fixes for some of the conditions.
most like vent pipe broke.
take cap off and look at hole on left side.pipe should be attached to this hole and run through tank.if pipe broke off gas will flow out of hole.
1 - 3 of 3 Posts
