1 - 2 of 2 Posts
Hi all, I am in the process of fixing up my SV650 K2 02, at the moment I am looking at replacing the Speedo.
So managed to pick up a Vapor Trail Tech for a decent price, looks fairly straightforward to fit. Still v green to electrics, so learning the hard way :-\
I noticed once the old speedo was removed that the lights for the indicators, full beam etc didn't run through the speedo circuit board, so am presuming these will still work. That is all apart from the fuel light, this has one yellow wire connecting to the circuit board. Does anyone know what this does or whether the fuel light would still indicate if not attached to the board.
Has anyone on here done a custom dash light set up?
Thanks
BannedCampCounselor
Do a search through some of the older threads for the Vapor and for the fuel light, there's a diagram floating around that explains how to hook it up and get it to work on aftermarket gauges.
It's not a simple plug and play, but it can be done.
1 - 2 of 2 Posts
