1 - 17 of 17 Posts
· Registered
For some reason I thought the bolts were the same when removing the fuel cap bolts. There are 3 that are the same and the with the remaining two: they are different. Does anyone know what the pattern is for re-installation?
Here's what I'm looking at (allen bolts):
|=== (thicker thread than the above three)
I'm not sure which one fits in which hole. The bolts make a star pattern if you are looking directly down on them from above the tank.
Any help would be much appreciated!
Thanks
· Registered
If you took all 5 out already, you should be able to lift out the fuel cap assy and look at which have the longer threaded inserts. I am guessing long in front (x1) and in back center (x2) but I dont have my SV near me to validate this.
Thanks, but I'm trying to recover from a lost key situation and cannot get the whole thing out. I was going to try to see if the key code was imprinted on the cap somewhere on the bottom (I had read a thread about lost keys and saw that it might be printed there), but since I cannot remove it that doesn't seem to be an option. So, I just wanted to reassemble it.
· Registered
If you place the shorter ones in the wrong hole won't the just drop in flush? Then take them out and put the longer one in and the shorter ones in the other holes.??? I would imagine if you put all the screws in the right holes they would be sitting at the same height unscrewed all the way around.
I'm bored so I will go out and look for you. You lucky bas****
· Registered
Ahh, drill it out might be best option but I do think my pattern is correct.
Thanks, that was the pattern.
Now I guess I'll try to pull the ignition assembly and see what a locksmith can do. I'm dreading the inevitable which is that they can't pick it to find the sequence of the cut. ~$200ish down the drain on a new lock set. I should have had a couple sets made when I bought it used last summer while receiving only one key. My mental excuse was 'I have never lost a set of keys in my life', so it took a low priority. :rolleyes:
· Premium Member
I have heard that if you can get the blank a good smithy can cut the key.
· Registered
Then your weird! Everything you explain should be explained as if you were sitting on the bike.
You are one funny guy.;D
Haha, Thanks to the both of you. Just FYI, I have 5 bolts total (obviously), 3 are a certain size the last two are thicker threads but one is shorter than the other. Either way, I took a 50/50 and guessed correctly. I think I put the shorter one at the 2 o'clock and the other at 10.
Now, big question. What size are the ignition bolts? I'm thinking T40S; does this sound right or should I post a new thread?
Thanks again
· Premium Member
Thanks again
Not sure but they are 'security' Torx bolts, set of Lisle STorx from pepBoys was $18.
· Registered
Discussion Starter · #13 ·
Just a quick follow up; I'm back on the road with new keys. Can I get a suzuki dealership to cut a new OEM key with a copy? The new keys work, I just like the look of the stock one although I know I'm being obsessive with that.
Here's what I went through:
1) Located a secure torx 40 - $7
2) Removed front fairing and all associated bits
3) Removed ignition
4) Discovered the wire is buried deep within
5) Lifted tank, requiring removal of seat
6) Removed radiator
7) Tried to remove the inner plastic piece that covers electrical connectos, driver's side plastic bulge screw refused to come out.
8 ) Pulled down plastic wire cover far enough to remove ignition wire
9) Paid about $45 to have locksmith re-key ignition with 3 non-stock keys
10) Reassembled everything and rode around a bit
Not bad considering I was facing paying $225 to suzuki for a new lock set.
· Registered
You mean he just made keys based on the ignition and not that he completely re-keyed keyed the ignition such that the original key wouldn't fit, right?
EDIT: because otherwise in less then 150 miles you'll be back there. ;)
· Registered
Discussion Starter · #16 ·
Ahh yes, it's keyed based off the original pattern. That was the first thing I checked when I got home. ;D
1 - 17 of 17 Posts
