If the axle bolt is slightly out there is a chance that the wheel could be misaligned and something is rubbing maybe the rotors?
well i loosened the pinch bolts, tightened the axle a little more, then tightened the pinch again and the noise is gone. the axle is a little bit more stripped, but i should be able to get it out with no problem and the new axle in.
