I would hate for you to spend the $$ on a set of LED bulbs that aren't going to do much for you then go right back to halogens. I'm also more than willing to answer any questions you may have related to what is below.
When it comes to bulbs you should stick with what the projector or reflector was designed for. If you think about it, there is a reason why car manufacturers / headlight manufacturers don't use these LED "bulbs". It's because they don't really work all that great.
Hxx = Halogen (ex. Hb4, H4, H1, H7, etc.)
D#x = HID (D1s, D2s, D2r, D5s, etc.)
No designation for LED Bulbs because they shouldn't be used.
I did an actual retrofit with OEM LED projectors. Here's some photos to show what OEM LED looks like. Notice the HUGE Heatsink and no use of a bulb. OEM LED also doesn't use flimsy copper strings and only 1 type uses a fan. In the second photo I removed the lens to show the LED chip.
OEM LED Output (~60ft-75ft):
Tuned LED Output (My final result ~100ft-120ft):
Agreed, I wouldn't recommend LED PnP bulbs. You'll also blind oncoming traffic which is dangerous. I plan on doing a proper HID retrofit into my bike. Being able to see a good distance is important when riding so having a LED bulb with a ton of foreground lighting will diminish your ability to see further ahead as your eyes will be focused on the foreground light.Well both of those concerns are valid. I'd recommend staying away from the plug and play LED "bulbs". Either switch Halogen bulbs to "Philips Racing Vision H4" or if you're stuck on LED's then go with a quality LED unit like JW Speaker or Morimoto. The other option is to retrofit a set of projectors (HID or LED).
Durability/Quality:
There is a reason cars do not come with LED bulbs stock. They instead use a huge heat sink with projectors. I can't see those little fans (or worse the copper strips) helping much with heat dissipation. Let alone lasting for long. Right now everyone is trying to cash in on the LED craze and people are buying into it.. Pretty much everything on eBay is labeled "Cree" when most people don't know what in the world "Cree" is.. Also I would be willilng to bet that 99% of their lumen/lux (Lux is real world application) are lies.
Beam angle/Pattern:
Nope. I haven't seen a single LED "Bulb" that produces a decent beam pattern with a nice hotspot. The LED's can't emit 360 degrees of light like the halogen can. Also the LED chips are not always in the correct spot to mimic the H4 bulb.
So I'm sure someone will jump in with pictures claiming how great their's works but I'd like to see wall shots from 100ft. The issue with LED as well as HID plug and play bulbs is they scatter light instead of focusing it (The reflectors were designed for H4). The scattering creates a ton of foreground light which is the light directly in front of the headlight. While that may seem like the lights are better it actually greatly reduces your distance vision.
Funny word.necroposting
