Hello all, I took the forks off my Gladius (same as the 2g SVs), and all was well up to the point of trying to pump out the old fork fluid. On one fork, I can pull the rod (component #14 in the diagram) in and out fairly easily (with a small amount of resistance towards the bottom of the stroke); however, on the other fork (right hand one) it takes significantly more force to move the rod. I need to wedge the fork between the wall and one foot standing on it, and it still almost will not move. Next, I removed the bottom two bolts (previous owner seems to have messed with them, causing a leak; They're component #10 in the diagram) and the previously impossible to move fork now can't even keep extended and is completely loose. When I re-insert the bolt, the rod now ceases to move at all. Furthermore, on the other "normal" feeling shock, when I removed the bolt, the damping cylinder (components 11, 12, and 13 in the diagram) just fell out. Any ideas what these irregularities are from? Do I need new forks? Any help is appreciated.
Thanks in advance
Pic of the fork components:
Thanks in advance
