1 - 7 of 7 Posts
I bought a 03 sv650n and it had the gsxr set up i am having problems with the speedometer its jumping all over i have the speed sensor that reads off of magnets that was.put on rotor does anyone kno what year or anything about this setup. Thanks
Sent from my LG-P925 using Motorcycle.com App
Yours should have 4 magnets=4 pulses each wheel revolution.
Check to see all 4 magnets are there first.
If yes, adjust clearance between the sensor the PO installed and the magnets.'
Not much else to go wrong mechanically.
Thanks. Ther is a total of 5 magnets and they r all there but the sensor is like rite on them when they come around if i set the sensor to a magnet while the bike sitting it sucks to the magnet im thinkin thats way to close correct.
BannedCampCounselor
If your sensor is contacting the magnets they your sensor isn't secured.
Try remounting it. Proper.
very big dumb
check that the polarity of the magnets is correct (grab a separate magnet and they should all push or pull in the same direction)
You should have FOUR (4) magnets not five, making the jumping around readout understandable.
Change it to FOUR magnets, evenly spaced around the rotor.
(this is assuming you do have a 2003 SV as indicated)
Ok ill try doing that thanks for the info guys.
1 - 7 of 7 Posts
