1 - 3 of 3 Posts
Will the front end ie forks of a TL1000S fit on my 03 sv1000s or will I have to change more than just the forks
I did the GSXR1000 front end swap years ago and haven't had an issue. I used the 05'/06' which I believe are the same. If I remember correctly I reused my front SV rim as I believe the stock spacers and rim work with the GSXR axle but dont quote me on that. everything else you need to use GSXR parts. Also you cant use your stock or the GSXR clipons as they will hit the upper fairings, I sourced Ducati clipons as they had a 1.5" rise in them. I did use the rear shock from the same GSXR parts bike and it's made my SV amazing to ride.
Hope you get it worked out... definitely dont blame you from wanting to get away from the stock components.
53639
1 - 3 of 3 Posts
