try 15 . how do you ride ?
The 15w is the way to go, set at level of 105mm. Stock springs are ok for your weight, unless you're planning on racing.fivetoez said:Which weight fork oil do you expierenced riders think i shoud run in my 01 Svs........the stock oil seems too soft..............15w mabye??_____5TOEZ______i weigh 125lbs.
Fairly agressivley........i'll try the 15w!________5TOEZ_______im ashamed to say i haven't done ANYTHING to my forks in 47 thousand miles :coyote said:try 15 . how do you ride ?
Whew, you're gonna have some major crapola down in there. ;D Really, you should take them completely apart, clean everything thoroughly, and check the bushings for wear. New ones would probably be a good idea. If you're not up for that, at the very least buy an extra quart of fork oil and flush them out good before refilling and setting the level.fivetoez said:Fairly agressivley........i'll try the 15w!________5TOEZ_______im ashamed to say i haven't done ANYTHING to my forks in 47 thousand miles :![]()
