You using clipons or bars?
I've got clipons, LSL offset match, and I have Goodridge SS lines- I ordered the length for the forks I have (00-03 GSXR 750) and the length was fine with both the stock gsxr clipons and my LSL's. I've got enough room that I could easily go up another 2" with clipons (bars might be pushing it though).
I want to mount bars when I put my GSXR front end on, how do the GSXR legs compare to SV legs in terms of length? With my stock forks and dirt bars I'm currently running the stock lines but I've got a set of Galfer SS lines laying around. They are supposedly for a naked SV but one line is about 1/2" too short.
I just received these from Vaughan here on SVR. They're from a Superbike kit, so a little longer. (Which is good, since I've read the the GSXR ones fall a little tight if you use higher clipons.)
for what it is worth I bought my brembo master off a 04 zx10,it came with Hel(sp?) steel coated lines tha worked perfect with my LSL clipons and 2002 gsxr 750 forks.
Guys anyone uses HEL brake lines,2 line layout(2 leave the MC) after the GSXR upside down conversion?
I will install LSL 25mm rise clipons and the length may be tight.
Please tell HEL line length
