1 - 3 of 3 Posts
Hello guys, i'm trying to remove my flywheel. I have a puller that has to be screwed on the flywheel. I removed the imbus screws from the flywheel and hoped that i could use these threads. It seems that the threads are in the freewheel? can these be used for the removal?
Many thanks!
I bought a remover and it's just one big honkin' machine screw that screws into the center hole. Lube the threads, screw it in and it should just pop off. If you get some pressure on there and it doesn't pop, leave it (with the pressure on it) for a while, apply some heat, or rap on it with something. I have heard stories of flywheels that don't come off and guys just keep cranking and strip out the threads.
1 - 3 of 3 Posts
