1 - 11 of 11 Posts
they should yes. I have the lockhart phillips flushmounts and they cover the hole...except the mounting holes arnt in the right spots so you hafta make your own holes which is kind of a bummer. I think they make true flushmounts that fit in the stock holes perfectly
you can get flushmounts from watsen designs that fit the holes on the sv perfectly
you can also put the LP flushies on in such a way that you don't have to drill the bike - just one hole in the flushmount itself. take the cover off and remove the bulb. drill a hole through the center of the back of the flushmount. you can put a bolt though the hole and through the hole on the bike where the stalk was. now get a washer (or a few if you need to stack them) to cover the hole and put a nut on the bolt. now reinstall the bulb and cover, wire them up inside and you're set.
watsen flushies:
stranger... did you paint those signals? or did u but them that color?
and is there a website for those?
thanx man...
kevinb120 said:
WOW those are nice :eek: Are they at least as bright as stock???
I don't think anything is as bright as stock......but they are brighter than most LED signals. I have had no problem with people seeing them. Most bikers I ride with comment on how good they are.
Yeah, the watson blinkers are sharp, to say the least. And yes, the larger flushmounts will cover the hole without a problem.
Stranger hit the nail on the head with this one. This is how I installed mine and it looks perfect! And no holes in the fairing.
Who has a pic of the LP flushies on?
These are the only ones I have with the flushmounts on at the moment. If it doesn't rain (highly unlikely) today, I plan on getting a few more snaps of the bike.
1 - 11 of 11 Posts
