1 - 20 of 39 Posts
· Registered
Here are my pics of the dismantling. Nothing great or beautiful, just tearing it apart...
Before:
Seats, tank, bar removed:
Headlamp gone:
Holy dirty engine bay, Batman! (Carb throats have been covered since this shot was made.)
I gently tapped a screwdriver into each pinch point to slightly open the clamps--else getting the top triple off would have been nearly impossible. Even this way, it took a bit of "nudging" with a rubber mallet.
· Registered
"Security" type Torx nuts that hold the ignition in:
You'll need one of these to remove it:
Takes some force, as there's a locking glue in the threads:
Everything removed from the fork legs:
To lift it, I had J-Dog stand and support the legs as I lifted it on the motorcycle lift. As the chassis rose, the front forks just fell out of the bike. Very easy.
· Registered
Discussion Starter · #10 ·
Did you simply drill a hole into a torx bit? or buy a whole set?
What size is it?
I'm about to undertake the same project on my SV1000s...
Thx
I bought a set several months ago from some vendor on www.amazon.com some months ago. This particular bit is a T40.
· Registered
Egads, what bird built that nest of wires at the bottom.
That was from splices I had to put in a couple of years ago--when I put in the duals, I had a bird's nest of wires in the OEM bucket to hide, so I cut and spliced and moved the wires and connectors back into the frame. Trust me; it isn't as bad as it looks in the pic. The wires aren't tangled and can be pulled apart easily.
It was my first-ever attempt at rewiring a vehicle. Surprisingly enough, it was successful, and landed me the job I have now.
· Registered
is that carpet in there?
i picked up my security torx bit set a napa for 7 bucks. they keep them behind the counter right behind the aero-kroil (best penetrant in the world) so you have to ask for them.
what's with putting the kroil behind the counter?
· Registered
Discussion Starter · #17 ·
You gonna have your bike all ready for the 2009 SV Rally?
Yup. With a fresh paint job.
how much did you pay for the front end?
$400 for the complete front end, minus left clip on that was damaged in a crash.
$65 (shipped) for a complete left clip on from and eBay seller. Clip on, grip, clutch, controls.
$45 for stearing head bearing from www.twfracing.com
$8 for rubber sleeved steel clamps to attach the headlamp to the new legs.
Nope. Bare cement floor.
1 - 20 of 39 Posts
