1 - 8 of 8 Posts
Hello SV aficionados
Is it possible to refill the rear brake reservoir without having to remove the rear body panels?
I was looking around and it seems to me that the only way to open that reservoir cover is by removing the right, rear body panel.
Thanks and Salud :eek:ccasion14:
Remove the right access panel (same one you use to access the seat bolts).
Remove the bolt holding the reservoir to the frame.
You now can pivot the reservoir outward to remove the lid and add/remove fluid.
or just gravity bleed it
1 - 8 of 8 Posts
