1 - 8 of 8 Posts
Hey guys,
Ran into a problem with my bike a few weeks ago and I was only able to lightly dig in. However, finals are over and I would like to get the bike running again.
The symptoms:
The bike began to run roughly in the middle of a ride. It would have a hard time idling at stop. If I gave it full throttle there would be a slight delay followed by a surge in rpms before it died. I pulled over for a bit and decided to head home. after fighting it for a mile it actually started to idle again and run smoothish till I got home. after letting it cool down it has yet to start since.
So far I checked my air filter and throttle bodies for blockage, replaced spark plugs and verified that each cylinder was sparking. and put the bike in dealer mode and checked that I was getting no errors. and the fuel pump still primes when the key is turned.
so air? check, spark? check I guess its fuel.
I haven't dealt with any fuel injection in depth so I'm looking for pointers on what to check. My gut says it should be a clogged fuel pump filter, but any pointers would be useful.
Best advice would be to do the 'fuel volume' test....that'll tell you straight away whether you're getting enough fuel or not. 9-10 seconds should easily pump at least 5oz and a good pump/filter will do about double that. If anywhere close to the minimum...you need a pump and flush or replace the filter.
Good call on the test. I didn't go through the hassle of hardwiring the pump for a steady test, but I did 4 key on/off priming cycles and by my loose count should have been longer than 10 sec total. I didn't even get 4oz out of the pump. A bit more searching yielded the v-strom thread about bypassing the high pressure filter and placing an inline filter.
I'll order the parts soon and try that next week. Can anyone recommend a specific filter that fits in the sv frame well?
Be sure to check the fuel pump filter. It could be blocked up.
I was initially hesitant to pull the pump (and it can be a messy job) since I dont have a garage. But I was able to do it with two home depot orange buckets. Once I disconnect the tank, I flip the tank onto the bucket and get out most of the gas by holding it over. Once there is only a small amount left in the tank, i used the bucket as a "table" while I undo the fuel pump screws.
Discussion Starter · #6 · (Edited)
I was out of town for a few days and started working on the bike again today. Before jumping into the fuel pump I decided to rerun the fuel volume test one more time and with an actual stopwatch. So I jump the pump for exactly 10sec and got about 7-8oz of fuel this time. So using the fuel prime cycles might not have been the most accurate. And the fuel pump might not be the problem.
I reconnected the fuel line and tried to start the bike without the airbox so I could listen. I can hear something that sounds like maybe some blowback coming from the rear cylinder. It didn't seem relevant at the time but one thing I noticed when I first started investigating a few weeks ago after my ride was that the airbox had come off of the rear cylinders throttle body. Perhaps it had been blown off by some reverse flow? I haven't touched the cams or timing in a couple years. Could this be the problem? What could be the cause if so?
Otherwise what would be the next thing to check? Injectors?
Im going to go out on a limb and say dont make your problem more complicated then it has to be. You either have an air problem or a fuel problem.
If the bike originally had problems idling, and you found that your air filter was loose--- is it possible you have a vaccum leak? either on the seal itself or one of your air box vaccums are not pumped in.
Hey mate, what did you find?
1 - 8 of 8 Posts
