1 - 20 of 211 Posts
Stealing Nexus's format (again) for a fender eliminator review thread to prevent the post madness from spreading.
Please give your input on motorcycle fender eliminators. Product reviews for what you've seen and used. Fill in the blanks with what you like and don't like about the FE. No need to write a novel, just a few lines and not "They rock!" about the FE so others can see if this is the FE for them to use.
Also this ISN'T a question and answer thread, just reviews from current users.
Please quote the next post and fill in your thoughts.
Thanks for your help now to help others in the future.
If you've made your own, please state it and a writeup if possible.
Discussion Starter #2
Fender Eliminator Model:
Retains original lights:
Pros:
Cons:
Would buy again:
Price paid and where:
Notes/links to pics:
Discussion Starter #3
Fender Eliminator Model: Competition Werkes
Retains original lights: Blinkers only, but includes a really weak white license plate light to stick on to illuminate your plate (in one spot).
Pros: It did the job
Cons: ...But not very well and costs too dang much. The instructions are worse than having none at all.
Would buy again: No
Price paid and where: Too much
I added a STOPPER light bar to the bottom of the plate and sprayed the FE black.
The angle of the license plate bracket is at quite a degree, which I do like but cops may not (had it for over a year with no problems).
Very old pic of my bike:
Fender Eliminator Model: Dubtecv2 #1
Retains original lights: If you want to
Pros: Cheap, does the job well
Cons: None that I can see
Would buy again: Yep
Price paid and where: SVR, $20 shipped
Notes/links to pics: check the FS forum
Eliminator model - Can't remember the brand. Ordered by the dealer out of a catalog.
Retains original lights? - Yes, if desired.
Pros - Sturdy, heavy guage stainless steel. Small & lightweight.
Cons - Expensive
Would buy again? - Yes
Price - $99.00 @ America's Motorsports
Fender Eliminator Model: Dubtecv2 #5
Retains original lights: Yep
Pros: Inexpensive, works flawlessly
Cons: None
Price paid and where: $25, in the for sale forum
Fender Eliminator Model: OEM 2004+
Retains original lights: Yes
Pros: OEM and keeps all my lights / reflectors, legal
Cons: Not a perfect fit on my 08 ABS model, leaves a significant gap at my tail light (filled up with a bead of silver silicone).
Would buy again: Yes
Price paid and where: $150 from a fellow SVR
Notes/links to pics: [/QUOTE]
Fender Eliminator Model: COMPETITION WERKES for 2nd Gen sv
Retains original lights: no. Adds little mini blinkers which some will not be happy with because they don't protrude from the body. They pretty bright when lit though. And the LED plate light is bright as well.
Pros: looks good
Cons: license mounting location is suspect (I have yet to be pulled over for it). Over priced
Would buy again: if it was cheaper than list price, maybe.
Price paid and where: was on bike when I bought it, but have seen them advertised for about $135+shipping.
Comes with LED plate light and turn signals. Plate mounting frame is not intended to go where it is shown in the picture. It actually mounted far lower and was partially below the tire when viewed from behind. It is aluminum and was easy to bend the mounts in the opposite direction to raise it 4 or 5 inches for better visibility.
[/URL][/IMG]
Fender Eliminator Model: Roca (European). Possibly available through Street Fighters by Design (USA); BanditMania (UK); S2 Concept (FR)
Retains original lights: No. replace with flush triangular lights
Pros: Neat, clean, integrated appearance, color matched. Undertail & FE.
Cons: Requires modification/removal of tail tray, battery tray, some wiring re-routes and replacement connectors.
Would buy again: Probably, I liked this solution best for my 2001 SVs.
Price paid and where: ~$80 (?) used, from SVR seller.
Notes/links to pics: See personal blog -
Piece of tail... and follow-up, Tidy up...
I went with the Hotbodies one which is a bit spendy - ($190-$230), but it looks really clean and smooth.
Retains original lights: If you want to, including the OEM plate light
Cons: Leaves a bit of a gap, that I filled (sort of) with some extra tool box drawer liner I had laying around. I plan to upgrade to some neoprene next winter. Also only for 2nd Gen. Tough luck you curvy-types
Would buy again: Absolutely
Price paid and where: SVR, $25 shipped
Notes/links to pics: http://forum.svrider.com/showthread.php?t=96535
dang that license plate looks close... has ur tire ever hit it?
No - seems to be okay in that position and I'm 220lbs and have had passengers on the back. The only downside to this version is that the signals aren't that obvious during the day. If that doesn't bother you, it's a great kit.
Let's follow the format on the reviews and not simply post a picture of what you have. This is supposed to help educate buyers and isn't really meant for show and tell (although it might be a byproduct). Oh and if you want to sell something, make a thread in the for-sale section... geeezussss
Pros: Similar to Hot Bodies fender eliminator but cheaper ($60). Flush. LED are bright even in daytime. Easy install.
Cons: Had to cut out much of the plastic underside of SV to get it in. No pre-existing holes for license plate mount.
Would buy again: Yes.
Price paid and where: $60 - Amazon.com
I like it. Installed R6 license plate mount under it, slimmed down the mount and stuck license plate on back. Wasn't sure first couple of rides but the mount, and everything has no issue of falling off or getting loose (thank god).
**grrr... no image**
Fender Eliminator Model: Targa
Retains original lights: Could, but the kit came with its own. Not my favorite but they work.
Pros: Easy to install, keeps plate/signals visible.
Cons: The license plate light is pretty lame, just a single led that's like 1/16" away from the plate. Kinda expensive.
Would buy again: Sure.
Price paid and where: $100, local Parts Unlimited dealer.
Fender Eliminator Model: Hamicad
Pros: Retains original lights including the license plate light, looks clean, easy to install with no cutting or modifications to the bike at all.
Cons: A bit pricey but worth it IMO.
Price paid and where: $120 direct from Hamicad in the UK. Took 3-4 days to arrive via Royal Air Mail.
+1 for Hamicad. I got one a week or two ago. Nice piece. Not just a bent piece of tin. Powder coated stainless, bent and welded to make it rigid. Nice craftsmanship. Perfect fit. Looks very "OEM" I don't think even the blinker patrol cops around here will hassle me over this one.
1 - 20 of 211 Posts
