1 - 11 of 11 Posts
I heard a rumor from a local motorcycle shop that they did not make the lower fairings for the '99-'02s. Im guessing its because of the change in '03 and thats all they make. So if you have any info please holler on that.
Also, I was wondering if anyone used a Shark Skinz body lately? That looks like a whole new front and i have to put the windscreen on and have to make the headlight cuts myself.
Is there an easier way to get a lower fairing that can just be tossed on to the stock front/upper? I dont wannt be cutting it and junk, but if i have to to get a full body kit, i may.
Information would be apprectiated thanks. Ride safe.
They make lowers. Stay away from that shop.
did suzuki make factory lowers? I know you can buy aftermarket but not sure about suzuki making one?
I never really like the aftermarket lowers on the first gen s modle. full faring looks cool but next to the stock s faring the lowers look tacked on.
Can i get a part number? Anything. I would like a full body on my SV650S rather than just the little it comes with.
That place said they did not make them anymore... i will have to call around and see if anyone else has information on the suzuki part.
Thanks by the way.
Now that may be more correct, I just knew they were made at some point. If you happen to need silver...
http://store.azmusa.com/sv20silofa.html
I think there were different lowers from other companies, hopefully somebody will get in here and tell you because I'm not big into appearance mods.
I take it that i am going to have to look for a full fairing peice to just change it all.
IE:
http://www.kgcycles.com/prod01.htm
http://www.hotbodiesracing.com/sv650_02_bodywork.php4
http://www.sharkskinz.com/s/suzuki3061.htm
And so on. I have yet to see one where i can just add to the stock fairing. And these will look better but i will have to spend more and i will have to cut headlight holes out of the race body. I found street one somewhere and now i cant. I will keep looking and try around for some street fairing peices.
Thanks.
2wheeljunkie makes the street kit I think.
avc8130 said:
Suzuki does not make lowers for the first gen any more.  They are done with those.  You would have to find someone with leftovers or buy an aftermarket set.
ac
As i tried to state this entire time. So it is fact that they are not made anymore. And it is fact that i have to find a kit somewhere. Thanks.
Ebay... Or if you can speak French and don't mind the postage and having to spray them up:
Poly 26 lowers. Lovely...
1 - 11 of 11 Posts
