21 - 36 of 36 Posts
I got my '22 with 1 mile on the clock. The pipes changed colors on the way home, about 60 or 70 miles.
Zero problems with the bike. This is today. I thought they were a bit more blue when I got it home, actually.
Discussion starter · #23 ·
Do you think the color of the headers of my bike indicates that it is running right or its running lean? The pictures is on my reply to troy jollimore
Discussion starter · #27 ·
so it's running lean but not lean enough to damage anything? Also I noticed that When I ride my bike it is hot on the legs. If I try to ride with shorts only, it so hot that, it is uncomfortable to grip the tank with my legs. but the temp gauge only shows 3 bars which is normal. I dont know if that heat that is uncomfortable is normal. When I ride with gear, I can feel less heat compared to no gear.
When I started riding all bikes had chrome pipes. Naturally when I bought my Gen3 I wanted the same so out came the solvol.
Dull, tarnished pipes make a bike look old, imho.
My bike at about 7 years old, looks pretty much the same now (different seat) at 9 years 43k miles.
Sorry to have derailed the post.
So the bogging is gone or still there? It took me a few attempts to make sure the slip-on was fully sealed before my bogging stopped, and since it went fully away whenever I put the OEM exhaust with gasket on, I knew it was the problem.
As for the speedo being wrong, have you looked into the speed sensor?
The hand soap? Or something from GB I don't know about in Canada?
Discussion starter · #32 ·
It is still there even if I put back the stock pipe. It bogs when the engine is at operating temp or when I ride for too long. It is also noticeable when putting it at first gear, applying throttle and clutch at the same time at stop.
Discussion starter · #33 ·
Nice Bike. Do you Think the color of my exhaust is normal?
That's exactly how mine acted when I had the exhaust leak. Really evident accelerating from stop in 1st gear and even more evident when it was hot.
Have you checked to see if there are any diagnostic codes on it?
The bikes are usually tuned a bit on the lean side to help pass Emissions testing. That would be my guess. I'm not sure on the heat, as I've only ridden mine in jeans. It's still pretty 'cool', though. I think I've only ever felt heat from the pipes/engine either on a really cool day, or on a really hot one when sitting in traffic. I for sure don't have the bogging you describe, though.
Discussion starter · #36 ·
I tried it and it say no codes (C00). my guess is that the bit that got stuck on the airbox clamp that keeps slapping on the secondary valve linkage affected the bike. Can I reset how the secondary valve moves? I feel like I need to adjust something.
21 - 36 of 36 Posts
